Hi
I just bought a 2001 6 spd with only 2900 miles on it. The GM records say all that has been done was recall # 04006, which is ‘’perform reprogram and functional test-manuals on”. I’ve been reading posts on the forum all the way back to 2005
about this CLB problem. I am REALLY confused now. I’ve read about K harness,
and fuel shutoffs, and locking plates…..and I don’t know what else. I’ve seen posts that praise the CLB, and I’ve seen posts that say they can cause all kinds of big problems. I don’t know what’s right and what’s wrong……
Ok, maybe you could answer some questions (again) for me.
What exactly does the CLB do? Does it disable the locking pin motor so the pin does not engage the locking ring? Does it keep telling the fuel pump that everything is alright? If I DID decide to remove the locking ring, would I still need the CLB to keep the fuel pump running? (but there’s no sense in removing the locking ring right?) Are the CLB and the K harness basically the same thing, so if I do install a CLB I don’t need a K harness?
I guess my scrambled up brain is telling me to do it this way.
I’m following these instructions, http://ls1howto.com/index.php?article=24
So here we go. Remove the knee panel. Unplug the correct wire junction terminal. Plug the CLB Into the correct side on the terminal, leaving the other wires doing nothing, put the knee panel back together, and that’s it…..nothing more, nothing less. Am I thinking right??
Sorry to bring up a well used subject again, but maybe now I’ll understand things before I tear into my new car. (which I haven’t even driven yet)
also, what happens to the car if the CLB were to fail??
Thanks again
Rod
Thanks again
Rod
