Rear axle drain plug
Nobody Cares
Higgins Lake , Michigan
red 81, orange 74 vert. , 80 claret,69 chevy pu
Hey guys (and girls ). Can someone tell me where the Plug is on the rear axle . Want to check the fluid level. No Hoist and close confinment. 81 Vette .Thnx Dave :w
ratflinger
South Central Texas
1979 Black Coupe, 396 SBC
Passenger side, on the rear cover, above the centerline.
Oops, you have a batwing so I'm not sure anymore. But It's still the most logical place.
Nobody Cares
Thats what i thought also ( most logical place), but i was trying to find the plug while lying on the ground and just couldn't seem too see the plug. Dave :boogie:boogie :w
HammerDown
Glenolden Pa
1981 White/ Red int.
Much easier to check w/the spare tire and lower shell removed.
I also (wayyyy back when) drilled and Tapped a front lower corner for a drain plug;)
Twin_Turbo
Enschede, The Netherlands
1982 Twin Turbocharged Red/Black
There is no drain plug, the fill plug is here (where the an hose comes out, of course the pump and hose is not stock equipment):
HammerDown
Glenolden Pa
Why do you have a hose connected to your Fill hole, that appears to be hooked up to a fuel pump ?
Twin_Turbo
It's an electric oil pump, it was a rear cooler setup.
