Help! Rear Brake Crossover Line
u2bdet
Staten Island, NY
Hello All , Found a leak in the rear crossover line (at the Clamp ) ORIGINAL lines , any ideas as to getting this off for replacement ? Lots of corrosion and as you know limited room !
Any advice would be much appreciated !
Neal
What I would do is soak it in wd40 or somwthing for a couple of days. Drain all brake fluid. Then clip the crossover line between the corners. Use two wrenches to remove the line pieces out of the corners be verycarefull not to distroy the corner pieces or buy new ones. Put the new one in and refill with fluid.
Something like this.
Greetings Peter
Thanks Peter , its soaking now , I would change the blocks, hoses and the line but I'm afraid of the MC line to the block ,dont want to get involved with that !
Neal
