Howdy all,
My right rear caliper kindly deposited DOT 3 on my garage floor until the rear reservoir in the master cyliner was empty. The calipers are original and at least the rear two have been bored and sleeved with stainless steel by a previous owner. The front two most likey have been as well, but I haven't gotten to them yet. I figure that if they have been rebuilt once then I should just replace them. Can/should caliper piston bores be successfully re-re-sleeved?
But the real problem...
After removing the right rear caliper and disconnecting the emergency brake cable the rotor should be wobbly and loose and slide right off with finger-tip pressure (previous owner drilled the rivets out). But not this one - it's stuck solid.
Does anyone have any ideas (other than a bigger hammer) how to get the rotor off? So far I've whacked it with a rubber mallet, and soaked it with penetrating oil. Tonight I think I'm going to try putting some heat to it.
Has anybody ever pulled a stuck rotor off with a large wheel/gear puller? I'll go rent/buy one big enough if I know it'll work, but I don't want to put too much pressure where it doesn't belong and mess up my bearings.
I have no idea what could be holding that rotor on there so tightly. I'm hoping it's just rusted on there and that Bubba didn't try to JB weld the rotors to the hubs after drilling the rivets out - but I don't think that's the case because the left side slid right off with no problems at all.
Semper Fidelis,
Culprit
Semper Fidelis,
Culprit
