Rear compartment rivets - how to?
  • Thread starter Thread starter smorrismi
The assembly instruction manual will show you where the screws go and where the pop rivets mount. If memory serves, the hinges screw to the doors which, in turn, screw through the compartment trim ring into the car. Trim ring is pop riveted to the underbody, but check this with the AIM.
Hmmmm. Yeah... I made note (always taking pics of the areas just in case) About where they go... My problem is how do I use the rivets? I put them in and cut them or hit them with a hammer? I should have been more clear about what I was asking... Sorry about that.
OH and THANKS for such a fast response. I love that... esp. when I want to get home and work on it this same day!
Pop rivet gun. Off the shelf almost everywhere, although it pays to spend a tad more and get one of a better quality than some of the generic items.
Ooodles and lots of small parts on C3s are pop riveted.
Perfect! Just another instrument of the trade to buy. Always fun getting more goodies for the Hot Rod. Restoration is an addictive artform isn't it. Thanks so much!
Just my op. I would not use the pop rivets. The originals were aluminun that have a 1/2 in head 3/16 th dia. And you peen them over with a punch and hammer. The reason is with the pop rivets you may have clearence issues when you close the doors. The mandrel sticks out and will prevent the door from closing.
Would you say that if I leave them off... the doors will still hold fine with just the screws then? I totally understand what your saying. The ones I got from corvette america are clearly smaller on the mandrel. But I want to be sure that there won't be any specific strain on any of the items if I don't use the rivets. Was this also the case for you with the rivets?
The doors and trim ring on my '68 did not have the large head rivets cited although the rivets are present in other places and applications. I used pop rivets and have not had any issues with trim ring or door fit or function.
Thanks for all the responses. I bought a decent rivet gun and the rivets supplied with the kit worked just fine!:)
