mlazinski
To keep a long story short, the gear bolts stripped and the diff. is toast as of three days ago. There was no fluid leak, but the rear end cover will have to be replaced. I searched the posts but did not find a consensus on rebuild businesses, can people please chime in on the best around? Has anyone used Corvette Perfection in WI? I am not going to try to tackle this myself. And as well, I am defentely going to change the gear ratio, want a little more off the line, but drive it at highway speeds quite a bit. Suggestions? 3.55? Thanks in advice for the help.
