Is there a template available for drill locations to install the letters on a 68-73? I will be helping install a set, and really would like to have something to go by.
Probably not. The AIM shows the installation of the rear letter kit, but no dimensions for hole spacing. The rear panels were received from the supplier with the holes already in them. That meant assembly line staff did not need to drill the holes -- hence, no instructions in the AIM.
VetteBoy: If you have a stock rear panel, you will probably be able to see the stock hole spacing from the rear. A flashlight will help.
