irving6421
New member
Have a 79 L-82. Was wondering if the rear crank seal is one piece or a two piece seal. Mine is leaking and in need of repair.
And if not replaced correctly,it will continue to leak..There is a fix..
When you replace it use an aftermarket seal because it is made to run in a different place on the crank.
