windrider50
I picked up a set of Prothane Poly rear stabilizer link bushings for my 72 BB, as the stock rubber has about disintegrated. My simple question is has anyone installed these puppies? I can't seem to figure out how the poly part is pressed into the bar end hole, and the hole in link.
A straight press in with lube doesn't seem to work, and my next attempt will be to soak the poly part in very hot water prior to trying to press it in.
Anyone with the obvious answer that I'm missing??
NJ BB Ken
NJ BB Ken
