John Robinson
Gone but not forgotten
I am wondering if someone can tell the symptoms of a rear hub thrust washer going bad. Can you replace just the washer?
I occasionally have a sound or feeling like the right rear axle is shifting and when I put the car up on jack stands there is some movement of the wheel up and down and front to back. I do not think the play is in the bearing it is more like in and out play what I am feeling is the wheel shifting on the shaft. It has been many years since I packed bearings and adjusted them for tightness so I could be wrong but my past experience tells me the bearing is OK and something else is my problem.
Also if it is the thrust washer is bad were can I get a replacement.
