rear tire alignment
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
Do the rear tires get aligned???I was looking at the back of the vette yesterday and the rear tires look like they are pigeon toed..:confused
thanks
:) Yes they have independent suspension.....just had mine done also.....it will bring the tire back straight again
I had a 4- wheel alignment done on my C4 by Mark at "MSI" in Roseville CA. The result was amazing. I know A trip to nothern California is a long way for a wheel alignment, but it is a cruiz in the Vette :). I'm sure that an alignment will make a big difference in the way your car handles. Maks sure the technician knows Vettes.
C3 rear alignment specs with radials is zero to 1/2-degree negative camber, and 1/32" toe-in per side, split equally across the thrust centerline. If they don't understand that and don't know what the thrust centerline is, go somewhere that KNOWS Corvettes.
