Stallion
A little background, doing a rebuild on my '78 Silver Anniversary (L48).
The engine is now operational and running well. After filling the coolant
at operating temp, I installed the radiator cap and shortly thereafter, had
a fairly major leak in the heater core. I would like to take the heater
core out to inspect (& replace if necessary). Problem is, I am not sure if
the heater core comes out through the engine side or the dashboard side of
the firewall. Neither way looks to be much fun at all.
I have searched the assembly manual and there is not alot of detail on how that all goes together. If it
is the interior side, is it necessary to remove the dashboard or how deep do
you have to go? On the engine side, it looks like the AC unit would need to
be disassembled in order to get at it that way. Any help here would be much
appreciated. From the manual it looks as though there may have been (2)
arrangements on the heater core. Mine has the hose connections coming out
the bottom (not the side).
Any ideas??? Thanks, in advance.
