Question: I will be doing the rebuid of both front and rear suspension with the body on the car. Is it more difficult? should I pay and have it done or can you do it with the body on without any issues. All I have are the tools and floor jacks. Thank you for all of your posts - GOLD info!!!!!!
Rodney25,
To begin with, I'm not sure that I can give you a proof positive answer, only you can determine your tolerance for this challenge. Yes you can rebuild or upgrade the suspension with the body on, in fact in some cases the body weight helps, but with some qualifications. This is a dirty nasty job that includes lots of dirt and grease. Its a knuckle buster that can be very frustrating, especially if there's excessive rust. In addition working under the car can be a major pain in the toosh. Having worked on dozens of vettes, some things are intuitive to me that may take some time to figure out for the beginner. Yes there are a few tools that make the job easier; an arbor press to press bushings in is nice, but not absolutely necessary for example.
Having said all that, if you are determined, and willing to take the time and learn as you go, and buy the tools as needed, it is doable. Be prepared to do things twice, be ready to ask questions, and do lots of research before you begin. However if you don't have the room, attention to detail, lots of time, some confidence in your abilities, and most of the necessary tools, it might be worth getting an estimate from a suspension shop.
Regardless of who does the work, I would recommend making a list of all the components you'll need to replace, and then pricing them. Add up the total cost of all the bushings and tie rods, ball joints, shocks, possibly the springs, etc., then add 20%. Consider the "worst case" for the vette being out of commission and then double it. Then consider what you might be willing to pay for someone else to do the work.
Don't let me discourage you too much, but I need to be realistic. I'm willing to offer advice, so if you decide to move forward with the rebuild, and you'd like to keep me involved, give me a PM and we'll set up contact. Also I'm sure that there are a lot of others on this forum that are much more experienced that I am. So there's plenty of talent available to jump in when you need them.
