stevolwevol
I'm going to have my differential rebuilt for my 77. Is there a protocol for breaking in the gears?
yes, no heavy acceleration for 500 miles if you replaced your ring and pinion
If not have at it
It helps to add an EP additive with your gear oil as well
Sent from my SM-T530NU using Tapatalk
Noise in the rear axle, especially when coasting, could be a bad bearing.
Sounds like the carrier bearings to me
Who's doing the repair?
Sent from my SM-N920P using Tapatalk
GTR, It sounds like you know your way around these pigs inside and out, backwards and forward. I would have to print your post, and bring it to the man doing the rebuild.
Why not synthetic?
If I use GL5, then why do I need the additive? Waste of money, or to slippery?
What about aftermarket gears? Are they inferior?
I'm sure you have your good reasons for how you go about things, but it's a tad over my head.
Glad to hear you have the car back and you're on the road.
GM gears will have GM, the date, and tooth count stamped in them. They are a good gear set. There are 6 bearings in the diff, 2 axle, 2 case, and 2 pinion.
The axle bearings are not shimmed. The case bearings are, in stock form they are either steel shims for 63-66 or ground iron shims for the 67-79's. These shims set the lash and preload. Too loose and the lash would be sloppy and the diff noisey. The pinion is shimmed under the large bearing to change the pinion engagement depth. I have seem them all over the place.
Gear ratios for 63-79's 273( aftermarket obsolete now), 308, 336,355, 370, 373, 390, 411 433 or 456. The 373,390, and 433 are not factory ratios. The 373's are better then 370, 390 was once a GM counter gear, 433 are not too commonly used.
Too many blue suits in ghost cars lurking about.
