recurve
aerie1761
Hatfield,Pa
1981 & 2002
How do I recurve my HEI on my 81vette
The advance curve values are programmed into the computer chip. Chip companies can provide you with a modified version, but its a bit on the high side ($300 - $400).
As Gerry says, you'd need a new computer chip.
If you switch to a pre-computer distributor, then the advance curves are a function of springs, weights, and such. You can buy kits of all the parts needed to change to a better curve. I seem to recall that it costs something like $25 or so.
Joe
You can get into a brand new HEI (first generation-style having both centrifugal & vacuum advances) that is complete and with performance curve ... about $150 for a taiwan copy ... or USA from GM about $225. A good used one from junkyard about $25 ... rebuild parts & curve kit'll keep the whole shebang under $100.
JACK:gap
I have done recurving and unless you have a problem with sticky weights or bad springs , it doesn't help a whole lot in terms of acceleration, ET , driveablity etc.
Most mild performance motors will be making power at more than 3000 rpm anyway and by that rpm you should have full advance all in .
IMHO the hassles, cost and fiddling of reprogramming an advance curve is not worth the performance increase if the car is working well.
