C
c4ever
Recently the 85 has had to crank for some time before starting. Ususally after initial start up in the morning. This car has always started at the touch of the key in any condition. I metered the fuel rail and upon turning ign on I get 40psi which goes right down to 0. Does not hold pressure at all. The car will start and idle at around 25psi and jump to about 30 psi when reved. Is this more indicative of a regulator or pump. I tried to pinch return line but for the life of me there is no access to flex hose. If there is they did a da*n good job of hiding it. Car idles and runs fine even at wide open throttle.
;help ;help
Carlo
;stupid
;help ;help
Carlo
;stupid
