corvette66
yet another post in the hopes of solving problems on my tore up 74.
on the pass side of the fire wall is a relay screwed to the cover of the heater box thing. do you know what realy this is? also right above that relay is another connector a plug of some sort and it is screwed in to the firewall, there is no cover on it though, but it is def a connector for something. i think there was 3-4 wires to it, one side there was a black wire plugged in, and the other side of the connector had 2 red wires i think.
also i found one relay under the shift consol, it is bolted to the trani tunnel, do you know what that one might be?
also what side was the alternator on in 74? usually the alternator is on the pass side. but the alternator wires are on the driverside. yet the motor in the car has an alternator on the pass side.
