Removable Rear Window
Mooser
Active member
Ontario
1972 BB Coupe
Soemone got too close to my window glass with a DA at some point in history. Does the glass come out of the frame? Or do you have to replace the entire unit??
It's not easy to get out. There are two screws and two roll pins at either end. I got mine apart and let a glass shop cut a new glass. It is tempered glass
Thanks, I'll have another look
I'll have to take another look, are they around the two "dogs" or over in the corners ?
(Figured it had to come apart somewhere)
Mooser
At both ends of the lower trim you should see a screw. Then you should see another hole, that the roll pin is in. That pin inside is on a 45 degree angle to the outside.
