87L98Z52
Will This Option Be Available On The New Z06,thanks!
agree! first, people think that just because the top is bolted on, it's an easy mod to unbolt the top. the top is bolted on to compensate for the manufacturing tolerances of the piece parts and sub assemblies that make up the overall frame assembly. something on the frame has to have bolts and slots to allow for slight dimensional variances in the final assembly of the frame structure. remember, this is an assembly line thing with parts coming together with tolerances that differ from part to part, or even from different vendors. second, since the frame is mostly aluminum, it has different dynamic characteristics than that of steel. constant flexing and twisting may have some long term effects on the aluminum, and maybe the fiberglass panels attached to it. i can see things like cracked panels/mounting points and broken frame welds. i would also think GM would void the warrenty on anything associated with the frame and body of a z06 that has the top removed. no flames, just my 2 cents -RoadReady said:Dave Hill said it would be "major surgery" as the top is bolted/bonded on and the car would be a flexible flyer.
Nope.87L98Z52 said:Will This Option Be Available On The New Z06,thanks!
