PeterR
What is the trick to safely removing the connector from the coolant temperature sensor on a '91 L98 (on right cylinder head next to plug #6)? The sensor has a nailhead terminal. I thought the connector would simply slide off or perhaps it needs to be pushed down and then slid off, but neither of these methods seems to work. I don't want to break the 28 year old plastic connector. Is there a trick to doing this safely?
Thanks.
Pete
Thanks.
Pete
