Removing/inspecting HVAC fan?
eRiCdWoNg
Maryland
98 pewter mn6 coupe
...I havent peeked down there yet but thought I'd ask here, how easy is it to get to the HVAC fan so I can inspect it? At the minimal setting, it squeeks and if I turn the fan off, it stops so this leads me to believe its the fan. Hopefully I can cure it with grease but if not I"ll replace the fan. Any advice?
Well it was very easy, only 3 bolts. Anyway there was leaves in the blower motor. I removed the leaves and now it is just fine, no more squeek! Yay...
