You are NOT being very clear about which bolts are broken. Plenum to runner(on top), Runner to manifold(at bottom), or Intake manifold to head(very bottom). Left(drivers side), Right(passenger side). Don't you have a cell phone that takes pictures. It makes it hard to help when there is about 20 different bolts and locations. EXAMPLE: Lower runner bolt by #8 injector.
Get me a picture with some kind of reference point, like the distributor or thermostat in it. Use a small piece of paper and draw an arrow on it and get it into the picture pointing to the bolt(s). I HAVE THIS ENGINE AND HAVE DONE THIS MANY TIMES. I WILL HELP YOU IF I GET THE RIGHT INFO AND MAKE IT EASIER FOR YOU.!
Don't try to be surgical here. It's not going to work. You have a "project" ahead of you. Drain about a gallon of A/F. Take pictures of how it is put together and comes apart, for your reference later. Everything comes apart in a specific order and MUST go back in the reverse order. Avoid bending the pre-formed breather rubber tubes and any plastic lines. THEY will break! Start at the front right removing hoses from throttle body and throttle cables on left. Remove the A.I.R. control valve, wires and hoses too. Work your way to the back. Remove and mark injector wiring and hold downs and get them out of your way. You are going to have to take it all apart. So take some pics and start as I said.
