ed_in_pa
Again sorry, I'm sure this has been addressed but the search isn't working. While I'm working on the rear end of the my 76 I'm thinking of replacing the current 9 leaf spring with a new 9 leaf spring. I need aguments pro and con to replacing it. I've already decided that I want the original type versus composite. It's not a daily driver and I don't drive it that hard. I'd like to keep it as close to stock as possible. The main reason I'm thinking about replacing it is because it's 30 years old. I assume it had to have lost something. Also any ideas where to get a close to original leaf spring. (The original is turned up slightly at the end of each leaf).
Thanks for your thoughts.
Ed
Ed
I bought the spring from midamerica, it cost around $120 or so. All of the parts dealers around here wanted twice that much. I was very simple to do, and it brought the rear of the car back up to where it should be. I would definitely recommend replacing the spring AND struts. You can get good replacements for $20 a piece.
