J
jkern
Does anyone have tech instructions (or know of a link to a webpage) for replacing a rear wheel bearing on a 67 roadster? Please email me a copy or the link. john.kern@ngc.com
EZG63Conv said:Just did mine... Probably takes about a day with a press. I used a slide hammer from Harbour Freight (which came with an axle attachment, about $30) to get the spindle off. Then with a large bearing attch and a heavy duty jaw puller got the bearing off the spindle. Went to a shop with a press and pressed the new bearing on. So I didn't damage the new bearing I used the old bearing against the new one to press on. Hardest part of the whole deal was making sure the right tools were there. Autozone has Timken bearings inner and outer for about $19 buck a set. EZ sends
GTR1999 said:I know this job well and have done it for fellow corvetters. I'm not bragging about it, but I am concerned when I hear about pressing on new bearings at another location then where you're working. It might be understood by many but some will think you just need to transfer the old shim and spacer with the new bearings to the spindle. This of course is not the way to do the joob. I'm not saying you did this just wondering what you set the endplay to in the process. I've taken apart spindles where the previous guy installed new bearings and left out the shims altogether. It's not particularly hard job but you do need the correct tools and understanding to achive success.
GTR1999 said:67-
I use a mag base with a C clamp even when I'm working with my setup fixture.
