SatansVette
Greetings all. I was hoping to gain some insight into my no start problem that has me stumped. It was running perfect, except for a little noise from the alternator so..., I purchased a new one and installed it in and ever since, it just will not start. Cranking it over and over, it eventually sounds like it wants to start when you let off the key but after a few weak fires, it just dies.
Sounded like weak spark so I replaced the Optispark distributor.... no luck, same result. So, I thought it's got to be a bad ICM so I replaced it, along with a new coil. After all that I am right back where I started, cranks and cranks with a weak firing at the end of a lot of cranking then dies.
So I'm wondering, could an incorrect Alternator, actually cause the computer to prevent firing?
