K
Kritter
I have a 73 w 350 that was running fine using a junk Q-Jet.
I replaced the junk Q-jet with a refurbished Q-Jet.
It was running fine with the old one other than a hesitation at low throttle, once I got the new one on it is missing on half of the cylinders. It was running fine with the old carb but now missing terribly.
I cleaned the distributor cap, and contacts in the cap, checked the plug wires but to no avail.
The choke is supposed to be manifold driven (little box on manifold) but my manifold doesn't have one. I've just been feathering the choke. Adjusted the cold idle so it would run when I started it, haven't even gotten to the warm idle.
Mixture screws are adjusted to 3 turns out, was 2 1/2 moved to 3 but no change.
Strange though, it would run before with the timing set in various settings. Now it won't fire on all cylinders no matter where the timing is set. When I let it run (missing and all) about half of the exhaust headers are cold, and the other half are hotter than heck. Hotter than when it was running on the street before.
Help
Help
