Rowingone-
What are you changing from and what are you changing to? When I purchased my car, it too had the wrong driven gear. When I switched to the correct driven gear, it would not work.
It would not work because my transmission had the drive gear for 3.73 and up rear ends and my car had a 3.36:1. My point here is that if your switching from between driven gears for a low to high rear end ratio or vice versa, you're going to run into problems.
hope you don't have any issues but wanted you to be aware if you do.
Regards,
brian
