N
Nigel_Aves
I've developed a fuel leak that appears to be caused by a leaking fuel return pipe above the gas tank. (I think this is true because I replaced the fuel pump (and carburator) and while testing that out is excatly when the leak started to occur.)
(Runs beautifully but don't like the idea of being a moving bomb!)
Could anyone please let me know the best way of being able to replace these rubber pipes ? I'm assuming I need to tackle it by removing the trim piece below the back window but if someone could give me a clue if this is correct I'd be very gratefull.
Many Thanks in Advance, Nigel Aves
