mcditalia
I've had a nice go at it removing my old oil dipstick tube. Eventually I had to use a threaded tap and bolt to pull it out. Now my replacement tube is hard to get in. I wil try freezing it and lightly sanding the surface of the bottom end to get it to fit. Any other tips?
Is there supposed to be a rubber seal between the upper and lower dipstick tubes?
Lastly, is the flange at the bottom end (about an inch up) supposed to be flush with the engine block when it goes in? I just realized that my old tube sat a little more than a 1/4 off the block. Now if it's supposed to be flush that means that I've been overfilling the motor with oil all this time.
