netnarc2
I just finished replacing the roof side panel weather stripping. That's the piece of rubber that runs along the side of the roof, where the window stops when you roll it up. If you haven't done it yet, it's not as easy as it appears. It's not difficult to do, but it takes a lot of time, because the only way to remove the old weather stripping is to cut it and pull it out bit by bit. Then you have to clean the old adhesive out of the channels so that the new adhesive will hold. I used everything from a Dremel Tool with a wire brush attachment, to a bent piece of wire to get the old adhesive out. If you're planning to do this task, give yourself plenty of time.
