Bolisk
A few questions
1) I have removed the diff from the car, cracked it open, and completely drained and cleaned out he inside. Now, my question is with regards to filling the diff with new lube. I know that I'm supposed to fill the diff up to the bottom of the fill hole on the side of the back plate. The question is. . .do I fill it up to there and then let it go. . .or should I check back from time to time (as the lube makes it's way into the bearings and clutchpack. . .to top it off again?
2) I want to replace my trans fluid. My trans is still in the car. I have a suction pump for pulling the fluid out. . .but how the heck to I get new fluid in!?!?!? Is there some kind of push pump that will squirt the lube through a hose and into the case? If thre is can someone give me a name and a link to an example product?
Thanks!
JonR
Thanks!
JonR
