Replacing the rod from ignition key to ignition switch
rodney25
New York
1975 Convertable
When I turn the ignition key the rod on top of the column that goes to the ignition switch does not move and the engine will not crank.
I removed the steering column. How do you repair or replace this. Does anyone know or have pics or video on how to do this?
Sounds like the ignition switch is bad. With the switch off the column, can you move the switch positions between Acc/Off/On/Start? Has to be that or a bad tumbler on column, IMO.
