Along with the other reasons to avoid a gear drive ... all good ones ... here's another:
Chains tend to pull the front of crank upwards ... into the main webbing ... where block is strong ... not a problem.
On the contrary ... most gear drives tend to push the front of crank downward ... into the front main cap ... which is not nearly so strong as the blocks webbing ... potentially a problem.
I spend a bit of time around circle track cars, Busch cars & Craftsman trucks. I've yet to see any of those race motors based on american V8 use gear drive. Good quality true roller set w/ double, seamless .250" rollers is all you'll ever need for a street car ... quiet, accurate, long-lived & nearly bulletproof. Maybe gear drive is good for dragster ... I dunno?
JACK:gap
