Hi there,
It has nothing to do with anything other than electrical flow through the injectors.
If one injector has LOWER resistance than the other 3, then all electron flow goes through the one bad injector. This, in turn, does not allow the use of electricity to open the injectors on the other 3.
The ECM has a default driver that, under EXTREME electricity flow INTO the ECM, will SHUT DOWN!!!.
This is a protection feature of the ECM>
That being said, I have never seen an ECM go bad due to injector failure, because it will protect itself PRIOR to failure.
Allthebest, c4c5
