S
SRReality
I've developed a leak on the upper passenger side rear of my radiator. It's a stock Harrison and I don't know it's history, other than it's 48 years old. My engine is a low mileage GM crate 350, so not original. Cooling has "always" been an issue since I've owned it (7 years now), but this summer seems to be worse. I've checked all the usual suspects: coolant, radiator cap, timing, thermostat, hoses, shroud, etc. It doesn't have a fan clutch installed, but it does have an electric auxiliary fan on the front of the radiator, with a switch under the dash. I've turned it on in a couple of parades, but otherwise don't use it.
Question is: send it to a radiator shop and have it rebuilt or buy a new Dewitt's or Wizard to replace it. Since my power train isn't original, I don't think the value is going to be affected by installing a good, after market aluminum radiator.
What say, Corvette gurus?
