Hey Come on it's not that hard
CLEAN / STRIP
Remove wheel
Buy some (SOS pads) and some (superclean)purple bottle.
spray down the wheel and tire (follow directions on bottle).
Take the time withe sos and an old wash mitt to get all impurities off of rim (front and back).
Dry with old towel .
Buy name brand stripper water soluble (spray bomb works best)
Follow instructions.
PAINT
When rim is
totally dry and warm,go to paint wholesaler or auto supply and buy the color you want to paint the rim and a bottle of primer and clearcoat.
Place both bottles in a bucket of (hand) hot water for ten minutes(trust me this works) shake well until ball inside moves freely.
Protect surroundings from overspray.
Don't spray too close (12" plus)or too much.If it runs just wipe off with a rag and some thinners.Try again after dry time.
Do a light coat of primer on the transition area (fins)on the back of the rim
Do a light coat of primer on the front of the rims(focus on painted area)
Use a small ceramic heater to speed drying time.
Do a second coat of primer front and back
Do a
color (light)coat on the back
Do a
color (light) coat on the front
Let it dry (1 hour)
Do a final coat turn wheel back and forth to ensure your covering all the corners and edges.
Let it dry at least an hour
Spray clearcoat
easy does it don't spray so close or so much that it runs.
Dry with heater or overnight in warm area.
POLISH
Use
turpentine to take paint off tire (works best)
Take
laquer thinner on tea towel (damp with thinner not wet)and carefully remove paint from polished surfaces
When all paint is gone from polished surfaces take some MOTHERS aluminum polish on a face cloth and polish (this takes some serious elbow grease).
I think you will like the results.
About a week later you can polish out the clearcoat on the painted area.
![Wave :w :w](/data/assets/smilies/savewave.gif)
