- Joined
- May 3, 2004
- Messages
- 175
- Location
- St. Louis
- Corvette
- 2000 Dark Bowling Green Metalic Convertable
I bought my LT4 convertible last month and had to fix a few things. One was a LTPWS sensor in the right fron wheel and the right rear rim was slightly bent, pulling the tire enough out of round to cause an out of balance type bounce at highway speeds.
The sensor was fixed (expensive), but the warning light still shows (Service LTPWS). The shop manual says the system needs to be reset to clear the codes. Do I need to take this to a Chevy dealer or is there an easy way to do this?
The other frustrating thing is that all the stock rims are not true. There is a slight wabble at highway speeds on each tire. When I was having the tires balanced, the mechanic showed me the tire spinning at 60mph and the tread line moved back and forth about a 1/4 inch. Is this a common situation with stock rims? I feel like I need to find a good set of mag wheels to keep from wearing out my tires.
