vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
Andrew
A couple of things here.. ( and jumping in mid post)
1) Are the arms loose again? If so I would remove one rocker arm and look at the stud.
The studs are pressed in, so as the heads heat up the metal expands and so should the stud to keep the press..but SOMETIMES the damn things just get pulled up!
Look at the base of the stud.. you will see a line of oil staining from where the old stud sat in.
From the base of the stud boss ( casting )
1/2 inch+/-1/32 to the base of the threads on the stud to 1 3/8 to the tip of the stud.
327 head 461 casting..but should be same.
Now I do not want you to panic...however if the pushrods are NOT bent and the springs are NOT binding AND you did not put a WILD cam in there( and the clincher ) the studs do not show ANY signs of pulling up.
You need to inspect the base of the lifters and check the cam lobe for lift.
If your ground the cam FLAT ( lack of oil, improper break in ) that is another remote possibility.... you DO need to check this.
If the studs are pulling out!
3 ways to resolve this.
Stock heads removed from car
1) Drill in the heads for threaded studs.. DO NOT ATTEMPT DO DO THIS ON THE CAR.. you have to fly cut to get the proper relief for the COOL new studs with guide plates ( See my post Mystery 327 next gen) in the C-3 section. They also make straight studs where you pull the old ones out and just tap & thread the new ones in... but you have to use some NASTY thread lock to keep em there ( not to mention the water jacket that runs RIGHT UNDER the stud bosses)
If you only one or 2 offenders.
2) Pin the existing studs. You hammer down the old stud back into position and cross drill at the base of the casting.. and press in a cold roll pin. USE SAFETY WIRE when the repair is complete!
3) New heads.
Vig!
3) New heads.
Vig!
