rocking seat
  • Thread starter Thread starter Dragonslayer
D
Dragonslayer
For some strange reason, my passenger seat moves back and forht when you sit in it. Not a lot but it is very annoying. Has anybody else had this experience, and is there a fix to the rock.
:confused :confused :confused :confused :confused
Yes. But only the passenger power seat rocks.
rocking chair
Have you made sure that the atachment bolts are snugged down? It may seem obvious, but an easy fix is always welcome.
Jim B
HI there,
There is a bulletin on the drivers side seat moving during braking and acceleration.
This is 02-08-50-002 for the drivers seat.
Being that both designs are very similar, and only that the passenger side is not used as much.
I would just remove the 15mm nuts, and look to see if there is any play in the adjuster itself.
However, it may be covered under your factory warranty, based on mileage and in service date.
So, I would just check it out, and if it is something simple, you will see it pretty clearly.
Let us know how you make out, c4c5:hb
Thank You for the information. I'll check on it right away.
