Sounds like you are setting it up where the cover contacts the button? You need to set it up where there is 0.004"-0.010" play between the cover and cam button. Install the cover, and then move the cam back and forth and measure play with a dial indicator.
As for assembly lube: Don't use any on the cam or lifters. The lube can clog the roller bearings and prevent the rollers from spinning. Soak the lifters in mineral spirits for a while. Then soak them in 10W-30 engine oil over night. This is the recommended procedure by comp cams.
As for using a bronze dist gear: If the cam is a modern design intended for street use, it will have a cast iron dist gear pressed on the back. With the press-on gear, you don't need a bronze dist gear.
Good luck. Big blocks love roller cams. I've had one on my 454 for over a year now and love it.
Markus '71 454.
