Dunzvett81
Hi Gents, I am trying to pin down my idle problem. When cqar is initally started up and is warm it idles not to bad. However, when car is driven about 2 mile or so the idle seems to be worse. It idles at about 750-800 rpm but it just sounds and feels a bit off almost like it is missing. I have replaced spark plugs, rotor, cap, wires, timing is 10 BTDC with a new cam, lifters, balancer, chain etc.. I just repalced all vacuum lines for the headlight system and i am getting 20 off the manifold. I know pretty much anything could cause a bad idle but would a vacuum leak cause a rough idle as i described. The headlight actuators are new however the relay valves are not and I just ordered new ones, if they are leaking could it cause the problem? or would it be most likely linked to the carb?
thanks
thanks
