L
Likecars
Well, prior to shelling out 200.00 for my deduct thought I'd try here first (really second).
Car was running fine two weeks ago, thought it may be rebelling this week for making it sit by giving me a rough idle.
Been hoping it would work itself out, but no luck.
Here's what I have (2000 w/29,000, 6sp) rough idle after about 15-20 seconds of sitting. Not a I want to stall just a steady: smooth smooth rough smooth smooth rough type of idle. It has not quit or acted like it wants to. It accels fine out of first as if there is no problem. I purposely put it in 6th going slow to see if it would bog down, does not like that, begins to buck pretty good. 5th will do the same if in the low 30's (mph). A low 1 to 4th, ~20-25, will yield the same result.
I'm thinking fuel/air mixture, but do not know what to check. Will put some injector cleaner in for the heck of it. I have changed nothing and have pushed and prodded every visible plug and wire to see if that would help.
Oddly, I have also noticed the circulate / recirculate light jumping to the circulate on it's own, related????
Thoughts? I have not pulled up codes, will figure out how and post anything relevant. (only codes: BO - RFAU1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC )
Tx.
Tx.
