Mike McKown
I bought this car over thirty years ago and it runs the same today as it did then. I mention this only to ward off suggestions that the problem is from sitting idle. It is a 327/250 hp. The engine idles good. It pulls strong at anywhere from one third to wide open throttle. The problem is just off idle. Any gear. It runs rough, bucks, jumps and lurches. You either have to get your foot into the gas, let off the gas completely or slip the clutch or you will be embarrassed if there is a crowd around.
A long time ago, I changed plugs, wires, cap, rotor, points, condenser, the whole distrubutor and then finally ran a ground wire to the battery from the distributor. No luck. I have left the car parked for many years and when I knocked the cob webs off the other day and started it up, it ran just like it did when i parked it.
Sometime before I purchased the car, the original owner put a re-built WCFB carburetor on it. Tag shows the right number for my car. Problem is, in this area at least, re-built carbs were notoriously unreliable. I have come to the conclusion the metering rod spring is not correct tension and the off idle roughness is caused by a lean condition. I don't how to check for this and it has been almost 40 years since I have had a WCFB apart. "new,rebuilt ones" are expensive to be guessing about the problem. Can anyone offer a suggestion?
Thanks,
Mike
Thanks,
Mike
