7
78SilvAnniv
I just checked the 2-3 recent threads of a similar nature and they don't seem to shed any light on what happened to me and the 78 today.
I had washed 78 and drove around the 'block' to blow most of the water off before a towel dry. Halfway around the block (about 1.5 miles) a truck came screaming up behind me as I made a turn so I stick my foot into it and she downshifted to second on her own and we maintained about 70mph for about 1.5 miles before I needed to make a sharp right hand turn.
As I slowed to nearly a stop for the sharp turn, I observed the engine running 'lumpily' and very rough as though it was about to die! I gave it a bit of gas and she smoothed out and we cruised the last 1/4 mile at 30-45 with no problems. UNTIL...we came to a stop sign and she wanted to die again! I goosed her around and we made it to our driveway where I shut her down.
My first thought was 'water in the distributor'...but there is no way for water to get there the way I wash the 78. My next thought was a vacuum leak, but everything looked okay to me.
:confused
It was several hours before Kenny could look at her and he took off the dist. cap/rotor and found that it had fouled, so we replaced it. We numbered the new cap to coordinate with the numbers on the old cap, and also numbered the spark plug wires before removing them. Die-electric grease where called for.
Fired up...but ran even WORSE! :eek
I also seem to hear a hissing noise when we goose the throttle...is that a vacuum leak? Kenny plans on changing the spark plugs tomorrow during daylight. I also thought I heard something knocking, but it could have been something moving and hitting something with the engine rocking the car so much.
What are we missing?
Heidi
GM crate 350 @ 250hp. Approx. 25,000 miles on engine w/ tuneups, rebuilt carb and properly timed oil changes. Carb and plugs/wires were done in the last year to year and a half.
:confused
Heidi
