joshwilson3
I have an 89 auto. A couple of times. Once was from a cold start, and the other was when it had sat for 30 minutes. I start it and it idled real ruff dying or trying to die. So, I had to raise the RPM's to keep it from dying for like 10-15 seconds, then all was fine.
It has just done this twice. Any ideas on what could/would cause that?
I've replaced the spark plugs last year. The wires, cap, and rotor have been replaced by the PO. Last year I pulled the throttle body off to clean it. And I think the IAC had been replaced by the PO because it was very clean. I reset the TPS when I put the throttle body back on. The PO also had the injectors replaced and the FPR. I've replaced the PVC, knock sensor, and 3-way check valve. The timing has been checked.
