C
cmegga
I just had a total rebuild and now the engine may be running hot, the car always ran faily well heat wise, pretty much flat at 205. I had the block machined 20 over and now that is all back togher Im showing 240-250 or so on guage.
My mechanic did two heat sensors all new hoses and a radiator flush, which he said looked fine (the radiator). I also have a brand new edelbrock water pump and 160 thermostat.
After a while he finally ran it with the radiator cap off and took a reader from the coolant itself with a manual meter. It was right at 200, while my guage was reading at 250.
What would cause the gause to suddenly go out of wack after a rebuild, and how can I correct it. Or could it actually be 200 in the radiator and 240 inside the block ??? Any better way to test this ?? I really want to be sure its not going to burn up after all the money I spent on this rebuild.
Any info would be apreachiated.
