LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
So I tapped into the O2 sensor output so I could monitor the O2 output with a DMM and adjust the idle mixture, dwell, etc....so I could try to get near the 14.7 A/F ratio which would be 0.5Vdc.
Did not matter what I did, adjust the idle air mixture screws or idle air bleed valve screw...I could not get an average voltage reading of less than say...about 0.8 volts....which means running rich.
I have the dwell varying between 30 and 40, idle RPM at about 700-800.
I do have the HyperTek PROM as the stock one was dead when I got the car....do not know if that makes much diference at idle..doubt it.
Any suggestions??
Any suggestions??
