S
Steve40th
LT1 MAP sensors are located on front/top of manifold, passenger side, with three pin plug under it. It has a cheap little orange gasket that it monitors pressure/vacuum with.I pretty sure it does, but someone else will probably chime in..![]()
A code 36 is the high res portion and the car will run with it. If you get the 16 it is toast(opti).
Pull harness from OPTI and use electrical cleaner and put dielectric grease in there.
