D
dchatcher
I have a '96 LT1 Engine and need to know the location of the serial number and as I understand it, the coolant flow on this engine is reversed from normal - engine outflow at the top of the radiator and inflow at the bottom. Based on reverse of normal, from the hoses on the engine it appears the inflow to the engine was from the left side of the water pump to the radiator upper; and the pump outflow from the right side of the pump to the lower on the radiator.
Is this correct?
Is this correct?
