woodstockdrift
Hello this is my first thread!
BRAKES
I haven't owned a Corvette so I dont know how the brakes are supposed to be. I don't feel a good or strong "bite" when I press down hard and they dont stop the car very fast.
I had the brake fluid changed last week and it improved the braking but not the "bite"
Is this normal or is the braking supposed to be as good as more modern cars? I have a 10 year old 4 door with good brakes nothing sporty and the bite is a lot better and braking is stronger.
BELT
I noticed the belt does not lock when I yank it hard. Someone said it does not work like modern belts and to test it from a hard brake. I have not been able to do that because of the braking I just mentioned. Anyone else know much about the belts?
NOT complaining about the braking if its supposed to be this way just figuring it out. Thanks for the help
RECORDS - 95 C4 Stock brakes and wheels
50 miles ago: inspect brake system and pressure bleed. replaced with DOT 4 fluid
4,000 miles ago: replaced power brake booster
8,000 miles ago: turned front rotors, replace rear rotors, replace front and rear pads (Delco pads), flush and bleed.
BRAKES
BELT
